MikhailModeratorI suppose, the cause is your localization. I reproduced the bug. What culture did you set for Rapid SCADA?
MikhailModeratorYes, you right.
First, it’s needed to implement math algorithm. It is better to develop a module for the Server app.
Then, configure user interface. How do think, to display it?
Do you mean PID like this?
MikhailModeratorAnyway, this is strange.
What version of Windows do you use?Is it possible to try Webstation and Scheme Editor on another computer just for test?
MikhailModeratorTry updating ScadaSchemeCommon.dll.
Copy it in C:\SCADA\ScadaWeb\binPlease tell about the result.
This reply was modified 8 years ago by
MikhailModeratorThank you 🙂
MikhailModeratorYes. You should use Random class.
In the Formulas table add a variable:
Random rand = new Random();Then use it in an input channel, for example:
rand.NextDouble()
MikhailModeratorYes, you have to create cnlFilter object before executing getCurCnlDataExt. Could you create a new topic for your issue, because this is “New ideas” subforum?
Example is here.
You need the Webstation app installed, because the components are the part of the web application.
Also check log of Scheme Editor in C:\SCADA\ScadaSchemeEditor\LogMay 14, 2018 at 5:39 pm in reply to: MODBUS TCP – Unable to write data to the transport connection #3711
Untick “Stay connected” checkbox in the properties of communication layer.
You should:
1. Create an output channel in the configuration database.
2. Specify the number of the output channel for a scheme component. And set the Action property of the component.
3. Create a command in your Modbus template.
MikhailModeratorYou should provide more info about the error. Use debugger tool of Chrome to get error messages.
MikhailModeratorOK.
Currently the screenshots are not available.
Try opening manometer_v1.sch. Does it work?
You have to include all the images from manometer_png into your scheme. -
