Image pack (Meter scheme) object unable to find
Forum Home › Forums › Understanding the Software › Image pack (Meter scheme) object unable to find
  • #3686
    dineshkumargowd
    Dear Sirs,
    I am using the image pack provided by rapid scada, but i am unable to find the object in scheme editor to change the number of channel. But it is visible in views, unable to find and edit the object in scheme editor. Kindly help how to find those objects in scheme editor.
    Link for image pack
    #3688
    Please provide screenshots describe you issue. To be honest, I don’t understand the problem.
    #3691
    dineshkumargowd
    Dear Mikhail,
    I have downloaded meters image pack from rapid scada website and started using them. I have given the input channel to the meter, but unable to find the object in the bottom which was default assigned to channel 843.
    Image link highlighted portion is not visible in the screen editor to assign new input channel
    #3692
    dineshkumargowd
    image for link
    #3693
    dineshkumargowd
    Try opening manometer_v1.sch. Does it work?
    You have to include all the images from manometer_png into your scheme.
    #7695
    bbailey
    Hello!
    I am struggling to install this image pack onto my server. I am using this page to help, however I do not know if it is a server or a webstation plugin.
    Where do I put the manosphere.sch?
    What is the step-by-step if it is different?
    Any help is appreciated!
    #7699
    Image pack is just a set of images. You could copy them to any location and use the images when select an image for a component property.
