Webstation output channel error Forum Home › Forums › Runtime Bugs › Webstation Bugs › Webstation output channel error Tagged: #Webstation #commands This topic has 2 replies, 3 voices, and was last updated 6 months, 2 weeks ago by Mikhail. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts May 10, 2026 at 6:36 am #17935 JoiceabrahamParticipant I am turning on and off a relay by giving ON or OFF, and 1 or 0 command from webstation. Webstation sends the command but the value in the current place shows error check below drive for details https://drive.google.com/drive/folders/1aNyHY6ZBdqGWuqzZEE7dyTnLf4d88jPG?usp=sharing May 10, 2026 at 8:59 am #17937 manjey73Participant The format should be On-OFF. The error is probably related to the fact that you need to set the byte order correctly. Or set up the address start correctly from 0 or from 1. May 11, 2026 at 8:15 am #17940 MikhailModerator Hello, For testing, you could set the format to an empty value. After you make it works, change the format to Off-On. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
