Using the new basic scheme components
Forum Home › Forums › Understanding the Software › Using the new basic scheme components
Viewing 13 posts - 1 through 13 (of 13 total)
  • #3708
    jacklondon
    Hello everyone,
    Sorry, but i cannot see or use the new basic components (button, toggle, led and link) in the scheme editor. In the scheme editor i have only Pointer, Static & Dynamic Text and Static & Dynamic Picture.
    PS: The version i am using is the newest one, main version 5.5.1, 5.2.1.0 (Scheme Editor).
    Thanks in advance for advisement…
    #3712
    You need the Webstation app installed, because the components are the part of the web application.
    Also check log of Scheme Editor in C:\SCADA\ScadaSchemeEditor\Log
    #3720
    jacklondon
    Hmmm,
    i got an error in the log file of the scheme editor.
    2018-05-17 12:54:40 <xxx><xxx><ACT> Load components from files
    2018-05-17 12:54:40 <xxx><xxx><EXC> Error loading components from files:
    System.NullReferenceException: Object reference not set to an instance of an object.
    at Scada.Web.Plugins.PlgSchBasicCompSpec.Init()
    at Scada.Scheme.CompManager.LoadCompFromFiles()
    #3725
    Try updating ScadaSchemeCommon.dll.
    Copy it in C:\SCADA\ScadaWeb\bin
    Please tell about the result.
    • This reply was modified 8 years, 5 months ago by Mikhail.
    #3727
    Anyway, this is strange.
    What version of Windows do you use?
    Is it possible to try Webstation and Scheme Editor on another computer just for test?
    #3730
    Also try unblocking the DLLs in C:\SCADA\ScadaWeb\bin
    See this.
    #3731
    I suppose, the cause is your localization. I reproduced the bug. What culture did you set for Rapid SCADA?
    #3732
    jacklondon
    Hi Mikhail,
    1. Updated ScadaSchemeCommon.dll. Unblocked it. All other DLLs were already OK. (Still no access to new scheme components!)
    2. Rapid Scada is set to default English (en-GB).
    2. Windows version is 10 Creators (ENT) Version 1703, Build Number 15063.1088.
    • This reply was modified 8 years, 5 months ago by jacklondon.
    #3738
    The web app must be in C:\SCADA\ScadaWeb because of this bug. Is it?
    #3739
    jacklondon
    it’s under C:\Program Files\Scada
    #3740
    You can do a trick:
    1. Create a folder C:\SCADA\ScadaWeb\plugins\SchBasicComp\lang\
    2. Copy the PlgSchBasicComp.en-GB.xml into this folder.
    The fix of this bug will be included in the next version of Rapid SCADA.
    #3743
    jacklondon
    Done that and it worked, thank you Mikhail!
    #3744
    Thank you too. You helped to find and fix the bug!
