PID Control
  • #3721
    jacklondon
    Hi folks,
    any idea how to create a faceplate for a PID? Would be much appreciated…
    Thanks in advance!
    #3728
    First, it’s needed to implement math algorithm. It is better to develop a module for the Server app.
    Then, configure user interface. How do think, to display it?
    Do you mean PID like this?
    #3736
    jacklondon
    Hi Mikhail,
    The PID algorithm is being handled by/in the PLC. I just need to implement the faceplate, for example, if you click on a valve, a popup (browser) window comes up or selects another view (via link?) with the visual PID faceplate and accordingly you can set it to auto/manual modes, show/set the process/setpoint/manual value in the faceplate/component (sending commands to corresponding PLC registers) and show the “level” (via dynamic pictures?)…
    As visual (conceptional) examples, https://ibb.co/jWiEGJ
    • This reply was modified 8 years, 6 months ago by jacklondon.
    #3741
    The existing Link component allows to redirect to another scheme where you can put needed components. It is planned to add a popup dialogs feature for links in this year.
