Random Number Generator
Forum Home › Forums › Understanding the Software › Random Number Generator
  • #3716
    eamonng94
    Me and my colleague are wondering if there is any possible way of implementing a random number generator with set minimum and max values. I would presume this would be created through a formula in the administrator application?
    Thanks for any help in advance.
    #3717
    Yes. You should use Random class.
    In the Formulas table add a variable:
    Random rand = new Random();
    Then use it in an input channel, for example:
    rand.NextDouble()
    #3719
    eamonng94
    Hi Mikhail,
    this is the formula i have inputted into the formulas tab:
    public double GetRandomNumber(double minimum, double maximum)
        Random random = new Random();
        return random.NextDouble() * (maximum - minimum) + minimum;
    However one problem i have found is that the numbers are coming from the same seed, so if i call a random number between the same values on two different input channels, it outputs the same number. Is there any way of implementing a formula, which for every instance of the source code, generates its own set of random numbers, different to that of another channel?
    #3722
    eamonng94
    Solved the seeding issue by removing the randomizer from the time loop, looks something like this:
    • This reply was modified 8 years, 5 months ago by eamonng94.
    #3729
    Yes, you right.
