write integer with command
Forum Home › Forums › Communicating with Devices › write integer with command
  • #3706
    Charles Cool
    I have been trying to modify a register in a PLC from RAPID SCADA. I can read the register with a dynamic text but when I click on it I do not get anything to input a number to modify the register.
    Could you explain the procedure to set this up?
    #3707
    You should:
    1. Create an output channel in the configuration database.
    2. Specify the number of the output channel for a scheme component. And set the Action property of the component.
    3. Create a command in your Modbus template.
