Viewing 15 posts - 3,346 through 3,360 (of 6,288 total)
  • in reply to: Modbus Comm Bug #7994
    To be honest, I think that your network connection is quite stable. It disconnects only once in a few days. It’s normal to break and reconnect sometimes.
    If you set StayConneceted=true, it should work more reliable.
    I suppose that disconnecting is caused by random network errors.
    The question is duplicated. Please don’t flood the forum by long XML. Use screenshots.
    in reply to: sec data save #7992
    Please explain what you mean.
    in reply to: URL in interface database not get updated #7991
    This issue was fixed in v5.8.2. Do you use it?
    in reply to: about module rapid gate #7990
    will the gate module send history data to server while network return to work to keep the data of server complete
    Yes, it can. You should provide links to screenshots of the module settings. So the settings can be understandable.
    in reply to: Table View transposition & max present tavle values #7989
    But Elastic Report doesn’t display current values. So you can combine it with Dashboard.
    in reply to: Table View transposition & max present tavle values #7988
    There is a lifehack to use Elastic Report, which can generate HTML, to show data as you need. Then use WebPageView to show the report in the explorer tree. I can provide more details if needed.
    in reply to: Get data from excel into DAT files #7987
    Just find in Administrator – Server – Generator. Using Generator you can set any value of any input channel.
    in reply to: Entering Data Into A Table #7986
    Could you provide screenshots of the settings? You’re on the right way.
    in reply to: No Communication now #7985
    Windows 8 has no future. To use with Rapid SCADA Windows 10 is better than 8.
    but there is no “scada” folder in there
    You copy the scada directory.
    in reply to: Write multiple modbus register FC=16 #7984
    You need only one output channel. Set the Command Values field to “Execute”, set Command Type to Binary and enable Formula used.
    Set the formula:
    new byte[] { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08 }
    Check how it works, and what are the register values sent as a result. Copy here communication log, containing the command.
    • This reply was modified 5 years, 5 months ago by Mikhail.
    in reply to: Write multiple modbus register FC=16 #7967
    A user can input only one value in the command dialog. It’s possible to send 2 values using formulas. What is the meaning of this command for a user? Is it possible to simplify input for him? For example, a user just click “Execute” and the predefined values are sent to controller.
    in reply to: Webstation To Slow #7966
    Hi Rich,
    If it happens again and you find a particular cause, please share info with us.
    in reply to: Get data from excel into DAT files #7965
    A utility should be developed to import data. Otherwise, only manual input one by one value is available.
    in reply to: URL in interface database not get updated #7964
    found server interface database not get updated to reflect configuration change
    Please provide more info:
    1. Which changes.
    2. What module or plugin does not update the changes.
