Table View transposition & max present tavle values
Forum Home › Forums › Understanding the Software › Table View transposition & max present tavle values
  • #7974
    Artos9
    I would like to ask about transposed view of Table.
    Is possible to present table as vertical view?
    | ITEM | Channel 1 | Channel 2 |
    Current| 100 | 200 |
    00:00 | 300 | 400 |
    etc.
    In table view period presented data is only two days.
    Is possible to extend time range in table?
    #7988
    There is a lifehack to use Elastic Report, which can generate HTML, to show data as you need. Then use WebPageView to show the report in the explorer tree. I can provide more details if needed.
    #7989
    But Elastic Report doesn’t display current values. So you can combine it with Dashboard.
    #8027
    Artos9
    If you could it will be very helpful.
    #8032
    First, you should install Elastic Report, configure it according the manual and be able to generate a report. Then I will tell how to embed a report in a web page.
    Please post a link to a report screenshot when it is ready. It’s needed to clearly explain further steps.
    #8074
    Artos9
    Elastic Report plugin works correctly.
    In link you can find modified report table.
    https://imgur.com/xVLRs5I
    Is possible to think about more complicated Table plugin in future with custom views (transposition, hour, minute table header, wider date selection)?
    #8086
    If you want to add a node in the explorer tree that open the report on a web page:
    1. Add a new record in the Interface table.
    2. Set
    Path to URL of your report
    View Type = WebPageView
    Title = HelloWorld\My Report (for example)
    In Rapid SCADA 6 we will change the approach of working with historical data. This will cause changes in Elastic Report.
    #8121
    Artos9
    Thanks you for description.
    Unfortunately page return Error HTTP 404.7.
    ElasticRepExample.xml:1 Failed to load resource: the server responded with a status of 404 (Not Found)
    Interface settings.
    https://imgur.com/S2RQRG9
    #8127
    You need 2 records in the Interface table: one for the report and the 2nd for the link.
    #8177
    Artos9
    Thank you. It works!
    I use additionally argument &period=-30 to show last 30 days report.
