Embedded Webpages
Forum Home › Forums › Understanding the Software › Embedded Webpages
  • #18053
    elee
    I have tried the Mimic-fame way and also the Dashboard-xml way to have a webpage on my views. One of my webpages works perfectly and I can control the device. The other webpage does not connect. Both devices are made by the same company (Control by Web), the one that works is a simple web relay the one that does not is the x406 (‘web enabled one wire multi-bus’).
    I am able to connect to the registers of the device via modbus, but I would like if the premade webUI could be added into views like the older web relay.
    There are settings in the device for login credentials, but I have disabled that for testing.
    Typically for control of a web relay device the url is x.x.x.x/index.html, http does not prompt for credentials, https does.
    XML file: <?xml version=”1.0″ encoding=”utf-8″ ?>
    <DashboardView>
    <DashboardOptions>
    <!– Widget AspectRatio = Width / Height –>
    <AspectRatio>1.33</AspectRatio>
    <!– Breakpoint: ExtraSmall | Small | Medium | Large | ExtraLarge | ExtraExtraLarge –>
    <Breakpoint>Small</Breakpoint>
    </DashboardOptions>
    <Widgets>
    <!– The total width of the columns in a line is 12 –>
    <Row columnCount=”3″>
    <Widget type=”CustomUrl” url=”http://172.30.1.222&#8243; /> <!– works –>
    <Widget type=”CustomUrl” url=”http://172.30.1.201&#8243; /> <!– does not work –>
    </Row>
    </Widgets>
    </DashboardView>
    Thank you for your help!
    #18056
    I suggest:
    1. Press F12 in the web browser to open the developer tools.
    2. Check the error details in the console tab. What is the error?
    #18094
    elee
    Solved…ish
    These newer Web Relays can be contacted via modbus or snmp.
