Red Hat Installation
Forum Home Forums Installation Issues Red Hat Installation
  • #18057
    elee
    When following the instruction for manual installation on Linux, the Admin and Webstation applications do not populate like they do in Windows.
    Does this instance require Wine to use the administrator tool?
    Thank you
    #18058
    Yes. Please check this topic.
    #18059
    elee
    Mikhail,
    When attempting command: wine [file path]/ScadaAdmin.exe
    the warning is that the program encountered a serious problem and needs to close.
    (downloaded 2026 zip from drive location)
    #18060
    elee
    Also,
    “The Administrator application should be installed on Windows. It interacts with Rapid SCADA instance, which is installed on Linux, remotely. You should add a new deployment profile in Administrator for remote connection.”
    Is there documentation on how to set this up? I do not mind having the administrator application on a windows machine. My RapidScada will be hosted on a Linux VM and ideally would not need much changes when fully stablished.
    #18061
    is enough to run the app. It was tested on Ubuntu.
    However, wine may need setup.
    Alternatively, you could try the web app created by @jurasskpark
    Link 1
    Link 2
    #18095
    elee
    Neither link worked on Red Hat, installed RapidScada on an Ubuntu machine and connected the administrator from a Windows machine as recommended in another thread.
    Thank you
    #18097
    Thank you for the update.
