Hi Friends,
I seem to be going around in a circle so would appreciate some help please .
I have tables set up showing my incoming data , works fine.
Now I have been trying to add a way so as the operator can click in the Webstation table and add some figures , say number of times the machine broke down .
I want to be able to take this entered number and use it in my formulas . I have tried adding an OUTPUT channel in the table but I cant seem to be able to access the numbers even though I can type them in when the OUTPUT box pops up in Webstation.
What am I missing …. I tried having the OUTPUT channel SetVal to a calculated input channel but …. well no good ..
Thank you gentlemen , I was near but missed the Cmd out !
So to enter data by hand into a table and make it usable ….
Add an INPUT Channel , (231 in my case ) ,Type = Calculated real , enter the OUTPUT Channel on the same line (1231 in my case).
Then …
Add an OUTPUT ,command type = Standard , tick FORMULA used , formula = SetVal(231,Cmd) .
