Get data from excel into DAT files
Forum Home › Forums › Understanding the Software › Get data from excel into DAT files
Viewing 15 posts - 1 through 15 (of 25 total)
  • #7960
    kcks66
    Hi Mikhail,
    Good day to you. I want to copy/import my historical data from excel into Rapid SCADA newly created real/calculated real channels. Then save into DAT files. Pls advice for how to do this.
    My excel historical sample data:
    https://ibb.co/rtSkxZ9
    #7965
    A utility should be developed to import data. Otherwise, only manual input one by one value is available.
    #7969
    kcks66
    Hi Mikhail,
    I could try the manual input one by one value method. Pls advice for how to do it?
    #7987
    Just find in Administrator – Server – Generator. Using Generator you can set any value of any input channel.
    #8020
    kcks66
    Hi Mikhail,
    I tried to manual generate value into Archive Data, as below:
    https://ibb.co/vXMytQh
    I can see the value is generated, as below:
    https://ibb.co/8rfRVbz
    However, I cannot see from the Chart, as below:
    https://ibb.co/VMVH7Kn
    Is there anything I missed out? Pls advice and thank you.
    #8022
    Status write “2”
    #8026
    Status write “2”
    Or any other positive status. All available statuses are listed in the Event types table.
    #8028
    kcks66
    Hi Mikhail & manjey73,
    I succeed generated value and show on Chart after Status wrote 2.
    https://ibb.co/bPNCt3w
    There were one value generated at 00:00 and another value generated at 01:00. Is there any possibility to join the line in between them?
    #8029
    Mikhail promised to implement this in the next version of Scada. Now you can try using Grafana for these purposes
    #8031
    The is a parameter of Webstation, named Chart Gap. It defined time period that is connected by a line. You should create data points more often than parameter value.
    #8037
    kcks66
    Hi Mikhail,
    It is worked after I changed the ChartGap to 4,000 sec.
    https://ibb.co/R2LZXkB
    #8038
    kcks66
    Hi Mikhail,
    I have new question to ask; can I generate value into new DAT file with date earlier than recorded?
    https://ibb.co/G0XVw6M
    I want to generate value into channels for date 2018 Jan 1 as example.
    #8041
    If you create the parameter in the same way as you checked this example, the file will be created ? If yes, try using the API
    #8046
    Yes. A new file will be created.
    #8054
    kcks66
    Hi Mikhail,
    I retry many times by using the Server Generator. But no new file is created. Pls advice and thank you.
    • This reply was modified 5 years, 9 months ago by kcks66.
