Forum Home › Forums › Understanding the Software › Webstation To Slow
- This topic has 5 replies, 2 voices, and was last updated 5 years, 10 months ago by
January 8, 2021 at 1:44 pm #7953
Rich Ex
ParticipantHi friends ,
My system was working fine but now Webstation is taking a very long time to change pages or show data.
I am doing all this at the local machine so I have no network issues .
Even if I just try to bring up the ‘About’ info it take about 3 minutes to change .
It was working fine and nothing has changed , its the same on Chrome , Edge and Firefox browsers… I cant seem to see an issue so help please .Thanks Richard
January 9, 2021 at 8:13 am #7958
Problem like this is difficult to diagnose. Did you check CPU and memory load in Device Manager?
May be the problem is related to network configuration. I mean if web requests go by wrong routes. Please also check network adapters: do you have virtual adapters created by other applications?
January 11, 2021 at 8:41 am #7962Rich Ex
ParticipantHi Mikhail ,
No I have none of what you mention .
It was a very strange issue .
I have fixed it now , I had to uninstall and then reinstall the software for Rapid Scada and now it is working again , this does show that it was not actually Rapid Scada that caused the problem I suppose so may have been a windows related issue as I did notice that there were Win10 updates waiting to be installed after the restart .Thank you Sir for your help
RichJanuary 11, 2021 at 10:20 am #7966
MikhailModeratorHi Rich,
If it happens again and you find a particular cause, please share info with us.
January 14, 2021 at 9:36 am #8021Rich Ex
ParticipantHi , yes it did happen again even after updating to the latest version .
—I have found the problem that caused the Webstation to grind to a halt —
I had a ‘calculated real’ channel that was writing events , unfortunately the input was changing very fast , this caused the Server events .dat file to get very big , over 68Mb in a short time and then slow the whole web station down to a crawl .
Once I turned off the ‘write events’ on the channel the issue stopped .
Hope this helps , Rich
January 14, 2021 at 1:38 pm #8025
Thank you for the info. It’s really too many events. However, we will optimize accessing events in the future to let the system continue operating in such case.
