Forum Home › Forums › Understanding the Software › about module rapid gate
- This topic has 2 replies, 2 voices, and was last updated 5 years, 10 months ago by
January 12, 2021 at 2:00 am #7977
ZeusParticipanthi
my xml file config is below<?xml version=”1.0″ encoding=”utf-8″?>
<ModRapidGate>
<Gate>
<GeneralOptions>
<Active>true</Active>
<ID>1</ID>
<Name>Gate 1</Name>
<MaxQueueSize>1000</MaxQueueSize>
<MaxWaitingTime>3600</MaxWaitingTime>
<DataLifetime>30</DataLifetime>
<OutCnlNum>0</OutCnlNum>
</GeneralOptions>
<ConnectionOptions>
<Host>10.63.24.35</Host>
<Port>10000</Port>
<User>ScadaAdmin</User>
<Password>672C3165774A308878A00927A987C759</Password>
<Timeout>10000</Timeout>
</ConnectionOptions>
<MappingOptions>
<CnlMappings>
<MappingItem localIDs=”101-105″ remoteIDs=”201-205″ />
</CnlMappings>
<OutCnlMappings />
<ObjMappings>
<MappingItem localIDs=”1″ remoteIDs=”1″ />
</ObjMappings>
<DeviceMappings>
<MappingItem localIDs=”1″ remoteIDs=”2″ />
</DeviceMappings>
</MappingOptions>
<TransferOptions>
<CurDataTransferOptions enabled=”true”>
<Trigger>OnTimer</Trigger>
<UseRawData>false</UseRawData>
<SkipUnchangedData>false</SkipUnchangedData>
<IncludeCalculatedCnls>false</IncludeCalculatedCnls>
<TimerPeriod>1000</TimerPeriod>
</CurDataTransferOptions>
<ArcDataTransferOptions enabled=”true”>
</ArcDataTransferOptions>
<EventTransferOptions enabled=”true” />
<InCmdTransferOptions enabled=”true”>
<PollingRate>1000</PollingRate>
</InCmdTransferOptions>
<OutCmdTransferOptions enabled=”true” />
<ArcUploadOptions enabled=”true”>
<SnapshotType>Min</SnapshotType>
<Delay>10000</Delay>
<MaxAge>1</MaxAge>
</ArcUploadOptions>
</TransferOptions>
</Gate>
</ModRapidGate>and this is my server input channels
<ArrayOfInCnl xmlns:xsi=”http://www.w3.org/2001/XMLSchema-instance” xmlns:xsd=”http://www.w3.org/2001/XMLSchema”>
<InCnl>
<CnlNum>101</CnlNum>
<Name>Simulator – Sine</Name>
<CnlTypeID>2</CnlTypeID>
<ObjNum>1</ObjNum>
<KPNum>1</KPNum>
<Signal>1</Signal>
<FormulaUsed>false</FormulaUsed>
<Formula />
<Averaging>false</Averaging>
<ParamID xsi:nil=”true” />
<FormatID>3</FormatID>
<UnitID xsi:nil=”true” />
<CtrlCnlNum xsi:nil=”true” />
<EvEnabled>false</EvEnabled>
<EvSound>false</EvSound>
<EvOnChange>false</EvOnChange>
<EvOnUndef>false</EvOnUndef>
<LimLowCrash xsi:nil=”true” />
<LimLow xsi:nil=”true” />
<LimHigh xsi:nil=”true” />
<LimHighCrash xsi:nil=”true” />
</InCnl>
<InCnl>
<CnlNum>102</CnlNum>
<Name>Simulator – Square</Name>
<CnlTypeID>1</CnlTypeID>
<ObjNum>1</ObjNum>
<KPNum>1</KPNum>
<Signal>2</Signal>
<Formula />
<FormatID>10</FormatID>
<UnitID>16</UnitID>
</InCnl>
<InCnl>
<CnlNum>103</CnlNum>
<Name>Simulator – Triangle</Name>
<ObjNum>1</ObjNum>
<KPNum>1</KPNum>
<Signal>3</Signal>
<Formula />
</InCnl>
<InCnl>
<CnlNum>104</CnlNum>
<Name>Simulator – Relay State</Name>
<ObjNum>1</ObjNum>
<KPNum>1</KPNum>
<Signal>4</Signal>
<Formula />
<UnitID>16</UnitID>
<CtrlCnlNum>101</CtrlCnlNum>
</InCnl>
<InCnl>
<CnlNum>105</CnlNum>
<Name>Simulator – Analog Output</Name>
<ObjNum>1</ObjNum>
<KPNum>1</KPNum>
<Signal>5</Signal>
<Formula />
<CtrlCnlNum>102</CtrlCnlNum>
</InCnl>
<InCnl>
<CnlNum>201</CnlNum>
<Name>Simulator – Sine2</Name>
<ObjNum>1</ObjNum>
<KPNum>2</KPNum>
<Signal xsi:nil=”true” />
<Formula />
</InCnl>
<InCnl>
<CnlNum>202</CnlNum>
<Name>Simulator – Square2</Name>
<ObjNum>1</ObjNum>
<KPNum>2</KPNum>
<Formula />
<UnitID>16</UnitID>
</InCnl>
<InCnl>
<CnlNum>203</CnlNum>
<Name>Simulator – Triangle2</Name>
<ObjNum>1</ObjNum>
<KPNum>2</KPNum>
<Formula />
</InCnl>
<InCnl>
<CnlNum>204</CnlNum>
<Name>Simulator – Relay State2</Name>
<ObjNum>1</ObjNum>
<KPNum>2</KPNum>
<Formula />
<UnitID>16</UnitID>
</InCnl>
<InCnl>
<CnlNum>205</CnlNum>
<Name>Simulator – Analog Output2</Name>
<ObjNum>1</ObjNum>
<KPNum>2</KPNum>
<Formula />
</InCnl>
</ArrayOfInCnl>my server cannot receive data from rapid gate,could you tell me how to config the server and gate to make it work right,best regards.
January 12, 2021 at 6:25 am #7978
ZeusParticipanti have make it work,but i have some question about this module,will the gate module send history data to server while network return to work to keep the data of server complete,for example the network is failed for some reason from 1:00 to 2:00 and back to work at 2:00,will the gate module send data in 1:00 to 2:00 to the server? if i want to realize this function, what should i do?
January 12, 2021 at 2:24 pm #7990
Yes, it can. You should provide links to screenshots of the module settings. So the settings can be understandable.
