MikhailModeratorI do not see this formula at the user manual.
You can use C# functions as well.
MikhailModeratorI suggest to use the same input channel number and output channel number to control the device tag. In version 6 the channels will be joined.
Can I have 20 input channels but having 10 output channels only?
Yes.
MikhailModeratorEach scheme is a one webpage. To select a scheme, a user clicks it in the view tree.
MikhailModeratorYou should check communication line log for the error details.
This reply was modified 3 years, 9 months ago by
MikhailModeratorMay I have any comments for the toggle problem encountered?
Please provide more info:
– screenshots of the existing settings
– actual behavior
– expected behavior
MikhailModeratorYou should try to use animated GIF in Scheme Editor with a Dynamic Picture component.
MikhailModeratorTo fix this issue, screenshots are required.
MikhailModeratorWe provide some commercial modules and paid services. We appreciate if you use them.
Before purchasing modules, make sure that the modules work as you need.
MikhailModeratorThe structure of Rapid SCADA directories is broken.
I recommend to reinstall Rapid SCADA with the default parameters.
MikhailModeratorWhat is meaning for this based on the status color?
Component color may depend on channel status.
LED – SEND COMMAND, it will be execute my command from input channel after certain time delay.
Action executes on user click.
MikhailModeratorKindly help to clarify if the action for draw diagram is to draw a diagram for user?
Yes, the Draw Diagram action means that a chart will be open when a user clicks the component.
The Send command action opens the command dialog.
The Send command now action send a command without a dialog.
MikhailModeratorTo copy a log, find the file on disk in C:\SCADA\ScadaComm\Log, open in text editor, and copy.
Screenshot also OK.
MikhailModeratorCould you provide communication line log in the moment when error command is sent?
MikhailModeratorCould you provide screenshots of the Server settings in the project?
Did you uploaded the project after settings change?
MikhailModeratorThe release is planned for this year.
Choosing between version 5 and 6 depends on the requirements of the system you are working on. If you describe the requirements, I could suggest the version. -
