Forum Home › Forums › Runtime Bugs › Server Bugs › server is unaviliable
- This topic has 5 replies, 2 voices, and was last updated 4 years, 1 month ago by
August 29, 2022 at 11:54 am #10599
291348113
Participantexcuse me, I take over the work from my classmate and it went wrong when i install it be the step of scadasever/svc_install.bat ,now i can get in the login page but when i try to login, it tells me serve is unavliable.
this is my scadasever.log
2022-08-29 10:11:35 <WRC><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
2022-08-29 10:11:35 <WRC><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
The interface directory does not exist.
The archive in DAT format directory does not exist.
The archive copy in DAT format directory does not exist.
2022-08-29 10:11:35 <WRC><SYSTEM><ERR> Normal program execution is impossible
2022-08-29 10:21:22 <WRC><SYSTEM><ACT> ScadaServerService is shutdown
2022-08-29 10:22:01 <WRC><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
2022-08-29 10:22:02 <WRC><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
2022-08-29 10:22:02 <WRC><SYSTEM><ERR> Normal program execution is impossible
2022-08-29 10:26:16 <WRC><SYSTEM><ACT> ScadaServerService is shutdown
2022-08-29 10:26:52 <WRC><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
2022-08-29 10:26:52 <WRC><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
2022-08-29 10:26:52 <WRC><SYSTEM><ERR> Normal program execution is impossible
2022-08-29 10:57:12 <WRC><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
2022-08-29 10:57:12 <WRC><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
2022-08-29 10:57:12 <WRC><SYSTEM><ERR> Normal program execution is impossible
2022-08-29 13:37:54 <WRC><SYSTEM><ACT> ScadaServerService is shutdown
2022-08-29 13:38:30 <WRC><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
2022-08-29 13:38:30 <WRC><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
2022-08-29 13:38:30 <WRC><SYSTEM><ERR> Normal program execution is impossiblebut i do have interface directory or DAT format directory in scada ,i don’t know how to deal with it.
thank you very muchAugust 30, 2022 at 9:25 am #10611
MikhailModeratorYou should check that the directories specified in the project for the Server application, actually exist on the disk.
August 30, 2022 at 1:46 pm #10613291348113
ParticipantI have copy everything the log mentioned to the scadaserve file however, the log still tell me the same result and can’t login in.
2022-08-30 19:48:47 <WRC><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
2022-08-30 19:48:47 <WRC><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
The 19:54 2022/8/30 in DAT format directory does not exist.
2022-08-30 19:48:47 <WRC><SYSTEM><ERR> Normal program execution is impossible
could you please tell me how to deal with it, thank you.August 31, 2022 at 9:01 am #10615
MikhailModeratorCould you provide screenshots of the Server settings in the project?
Did you uploaded the project after settings change?September 1, 2022 at 8:45 am #10617291348113
I can’t upload the project because i can’t log in.September 2, 2022 at 11:18 am #10627
MikhailModeratorThe structure of Rapid SCADA directories is broken.
I recommend to reinstall Rapid SCADA with the default parameters. -
