Modbus Device via Scheme Editor
Forum Home › Forums › Communicating with Devices › Modbus › Modbus Device via Scheme Editor
  • #10649
    victorlam
    I have used a formula to display the correct value. After using the formula, the value of the status of register 30002 30003 cannot be displayed and showed with —. May I know how can I select to display the field with the formula set already on my scheme editor?
    Also, now my value for 30002 and 30003 cannot be shown after the new formula. How can I fix this? After checking, I see the new signal number is 6 & 7 but it cannot be changed under Modbus template editor. How can this be fixed?
    Thanks!
    #10651
    Check if your Server is starting from the log or if it reports a formula error and its operation is impossible. Perhaps you made a mistake in writing the formula or divide the value by 0, so you have displayed ---
    #10653
    To fix this issue, screenshots are required.
