Commands (Output channel)
Forum Home › Forums › Understanding the Software › Commands (Output channel)
  • #10632
    victorlam
    From the manual, it shows that the output channel is 65535. May I know if I can execute the different commands at the same time under Webstation? Can I have 20 input channels but having 10 output channels only? Or there is any direct relationship between input and output channels with the restriction. From the manual, both channels numbers are 65535 as noted.
    #10635
    victorlam
    By the way, can I execute different commands or output channels at the same time here?
    #10643
    You can create and link only the output channel to the table. in version 5, there are no restrictions on the correspondence of input channels with output channels, a link to which output channel you specify in the input will be the same. Also, in the table of views, you can specify only output channels.
    #10663
    I suggest to use the same input channel number and output channel number to control the device tag. In version 6 the channels will be joined.
    Yes.
