Scheme Editor
Forum Home › Forums › Understanding the Software › Scheme Editor
  • #10619
    victorlam
    I am a new user for Rapid Scada and like to use this platform. For Scheme Editor on the setting of Dynamic text, I may be confused a bit. I observed that dynamic text usually used with the command “Draw diagram” together with input channel eg 102 or 1001 (learnt from the video). Then for the button, the dynamic text is using action as “Send command” with both input channel number eg 104 and output channel 102 used.
    Kindly help to clarify if the action for draw diagram is to draw a diagram for user? How about the action for send command and send command NOW? Do we mean that SEND COMMAND is to send the command instruction immediately without any further notice?
    Draw Digram
    Send Command
    Send Command NOW
    For Background color, what is the actual meaning for status color? Do we mean it can show the current status color from the screen? Will this status color changed from green to red if it is not normal?
    #10620
    victorlam
    For scheme editor, I try to test Toggle but this function is not working after trial.
    We need to enter the value for input and output channel. May I know the criteria to get the mechanism that the status can be toggled really for my trial.
    Behavior = Send Command NOW
    Input channel 104
    Output channel 101
    But it does not toggle here.
    #10621
    victorlam
    For scheme editor, I try to use LED but again the function is not working well.
    1/ I see there is status color for every color selection. What is meaning for this based on the status color?
    2/ I set input channel number as 104 and action is Draw diagram. Not sure if this is correct to get LED to be displayed with the correct status on the screen.
    Or I use the incorrect action for LED components? What should be the correct action for components LED?
    For the action lists, Draw Diagram, Send Command, Send Command NOW? Do we have any restriction on this for those components like static text, dynamic text, static picture, dynamic picture?
    Or what will be result for different combination used here? For example, LED – SEND COMMAND, it will be execute my command from input channel after certain time delay.
    #10625
    Yes, the Draw Diagram action means that a chart will be open when a user clicks the component.
    The Send command action opens the command dialog.
    The Send command now action send a command without a dialog.
    #10626
    Component color may depend on channel status.
    Action executes on user click.
    #10629
    victorlam
    May I have any comments for the toggle problem encountered?
    #10655
    Please provide more info:
    – screenshots of the existing settings
    – actual behavior
    – expected behavior
    #10661
    victorlam
    Thanks for the support. I try to write the program step by step and works now.
