Command Error
Forum Home › Forums › Communicating with Devices › Command Error
  • #10614
    victorlam
    I have tested the command many times but still was not clear why the command only works on the first row of the channel here.
    Please find my shared screenshot for review as below:-
    https://drive.google.com/file/d/1DJEuLQkw38QyBWGBBEguqqee88ZT2olR/view?usp=sharing
    https://drive.google.com/file/d/19hu6bPs6SwvlrItZWfAweOPDNIKB_f9Y/view?usp=sharing
    I can change any value for tag #1 here. But I cannot change any value for tag #2 using command. According to the communication log, there is error on command 2. Per my investigation, I can only notice that only channel 1 (the first row) can be changed via command 1. Is this a bug? or my incorrect interpretation on this command?
    #10616
    Could you provide communication line log in the moment when error command is sent?
    #10618
    victorlam
    Sorry, I cannot copy the log record and can only use screen shot. Is this okay for your side?
    #10624
    To copy a log, find the file on disk in C:\SCADA\ScadaComm\Log, open in text editor, and copy.
    Screenshot also OK.
    #10648
    victorlam
    Thanks for the reply. I try again and test if this works or not. Otherwise, I will report again.
