Error code
  • #10630
    victorlam
    Please find my log record
    Device 1 “Device 1”
    DLL : KpModbus
    State : normal
    Comm. session : 03/09/2022 13:34:39
    Command : 03/09/2022 13:32:06
    Comm. sessions (total / errors) : 1530 / 0
    Commands (total / errors) : 1 / 1
    Requests (total / errors) : 1530 / 0
    Current device tags data
    | Signal | Name | Value | Channel |
    | ******** Group 1 ******************** |
    | 1 | Element 1 | 5 | 101 |
    | 2 | Element 2 | 0 | 102 |
    | 3 | Element 3 | 0 | 103 |
    | 4 | Element 4 | 0 | 104 |
    | 5 | Element 5 | 31 | 105 |
    No archive data
    No events
    Commands (recent 10 commands)
    | Num. | Date and Time | Description |
    | 1 | 03/09/2022 13:32:06 | Command: type=Standard, device=1, number=4, value=44.000 |
    May I know when I execute command 2 and command 4, there is error encountered. There is no error for command 1, command 3 and command 5 (or output channel 101, output channel 103 and output channel 105)
    • This topic was modified 4 years, 1 month ago by Mikhail.
    #10656
    You should check communication line log for the error details.
    • This reply was modified 4 years, 1 month ago by Mikhail.
    #10660
    victorlam
    Where can I check the communication line log status?
    #10665
    In Administrator open Line Stats, then select Line Log.
