June 28, 2023 at 1:22 pm in reply to: Add channel name in Input/Ouput channel parameters in Scada Scheme #12893
Cool!
Is it still possible to enter channel number manually?
What is written in ScadaServer.log?
Did you copy that files when installed the plugin?
Could you share the GIF that causes the error?
Secret key of the client must match the secret key of the server. Copy the correct key from the Server settings.June 27, 2023 at 2:39 pm in reply to: Add channel name in Input/Ouput channel parameters in Scada Scheme #12879
Sounds useful.
Unable to open the links. Could you upload images to https://imgbb.com/ or Google Drive?
MikhailModerator🙂
MikhailModeratorTry 2301 order.
If it does not help, please post links to screenshots of the Modbus template.
MikhailModeratorYou could try writing data to kepserverex by sending commands from Rapid SCADA.
Commands can be sent manually or automatically. To send commands automatically, try this module.
The described approach works for a small amount of tags.
MikhailModeratorThey have different function code. So you need to select proper Data table in the Modbus template.
This reply was modified 2 years, 11 months ago by
Use https://rapidscada.net/modbus to parse the packets and find the difference.
Communicator 6 can work either as OPC UA client and server.
OPC DA client is available, OPC DA server not supported.
MikhailModeratorIn general, yes.
According to C/C++/C# syntax, the equality operator is==
Also you can check channel status, for example,Stat(1) > 0
MikhailModeratorHello Paulius,
You should create additional channel of the Calculated type to calculate a condition. Then use that channel in the trigger.
