Images sequence
Forum Home › Forums › Understanding the Software › Images sequence
Viewing 13 posts - 1 through 13 (of 13 total)
  • #12818
    TDE
    Is there any solution to show a sequence of images in the web station using the scheme editor?
    Thanks!
    #12826
    Could you explain how it should work?
    #12828
    TDE
    The work is about using an image dataset with different folders (15 folders each one has images between 5-15), and each time I trigger the sensor (1) It is supposed to show a sequence of images(img 1, then img 2 then …) from folder (1) and so on. Note that sensors (15 sensors) are not ordered ascending or descending.
    Thanks!
    #12837
    You could try creating animated GIFs and using them inside Dynamic Picture components.
    #12840
    TDE
    I’m asking about how to make Rapid Scada knows the root automatically of where the images are in order to show them depending on the triggered sensor.
    Second, if there is a feature which is useful to show a sequence of images, because I want to control of image appearance with a specific channel
    Thanks!
    #12847
    The images are stored in a scheme file. They are not loaded from some directory.
    There is no a component to display a sequence of images. A possible method is using animated GIFs.
    #12851
    TDE
    Is it possible to control the running of the animated gif? (for example if the channel 104 status=1 the animated gif is running, else it stopped if the status is 1 again, it continues from where it have been stopped.
    Thanks!
    #12853
    According to the condition, the animated GIF can be changed to another image by Dynamic Picture component. But the stop frame will not be restored.
    • This reply was modified 3 years, 5 months ago by Mikhail.
    #12880
    TDE
    I create a dynamic image and I matched it with the gif. The problem is that when I want to access the scheme editor of the scheme view to change or remove the gif or any modification this error appears:
    Unable to upload scheme to the web page.
    https://ibb.co/2WBWjcm
    Can you please tell me how to solve this issue?
    Thanks!
    #12890
    Could you share the GIF that causes the error?
    #12909
    TDE
    Thank you. I can check it the next week.
    #12932
    I also get the error with that GIF image.
    The problem is caused by the image size (15MB), it’s too big.
    We will investigate this issue when move Scheme Editor to .NET6 framework. Unfortunately, I cannot provide the exact date. Try to reduce the image file size.
