Connect two pc with RapidGate
Forum Home Forums Communicating with Devices Connect two pc with RapidGate
Viewing 15 posts - 1 through 15 (of 19 total)
  • #9778
    Nicoals
    I need help to connect two PC’s that have rapidScada and use OPC, they would have to connect with RapidGate but I can’t achieve it. If someone could help me, I would appreciate it.
    #9779
    Draw a diagram of what you want to do? Since RapidGate is not an OPC, it is designed to transfer data from one RapidScada to another RapidScada
    #9784
    Nicoals
    I know, I know that rapidgate is for data transfer, I need to connect two PC’s through rapidgate where one takes data from an OPC server and sends it to another rapidscada
    | PC A |——————————-| PC B |
    | recollec OPC data | |_receive data_|
    |_____and send______|
    • This reply was modified 4 years, 8 months ago by Nicoals.
    #9788
    Rapid Gate manual is here https://rapidscada.net/doc/content/latest/en/modules/mod-rapid-gate.html
    To get some answers, please ask a specific question.
    #9789
    RapidGate should be installed on the Scada side where you have an OPC poll, nothing is required on the second side.
    #9793
    Nicoals
    Just one side Rapidgate? Thank you.
    But how do I get the second PC to read the survey where my data is?
    I’m so new to rapidscada, that i dont idea
    #9797
    Twet
    HI, I need to make the same connection between two PCs with RapidGate, but with the configuration of the PCs, in my case one emits the data and the other receives it, but I can’t connect them.
    How would the PCs connect, where does my PC that receives the data have to point, to localhost, or to the RapidGate module?
    #9803
    The main PC:
    – Does not need Rapid Gate
    – Has static IP or DNS name
    – No controllers connected
    The “remote” PC:
    – Polls controllers
    – Needs Rapid Gate
    – Can have dynamic IP
    – Rapid Gate initiates connection to the main PC and uploads data automatically
    • This reply was modified 4 years, 8 months ago by Mikhail.
    #9812
    Loonngg
    Hello, Im trying to make the same connection as Twet, but my Rapid Gate doesn’t make the connection to the main PC. This is the configuration in the Rapid Gate: https://imgur.com/a/PbEcasE
    is this configuration ok?
    #9814
    Check Rapid Gate log file located in C:\SCADA\ScadaServer\Log for error details.
    #9823
    Twet
    In my main PC I only have to create a line and a channel for the reception of the data?
    #9827
    Usually devices are polled by the remote PC. The main PC only processes input channels.
    The both configurations, for the main PC and the remote PC, should be created within the single project that has 2 instances.
    #12725
    RapidScadaHan
    Dear Mr.Mikhail,
    I tried install a rapid gate on remote PC, but I can copy the module configuration files ModRapidGate.xml and ModRapidGate_Reg.xml into the edited project because I can not see them. Where these files ModRapidGate.xml and ModRapidGate_Reg.xml are located?
    Thanks a lot
    #12729
    ModRapidGate.xml and ModRapidGate_Reg.xml are created automatically in the proper location of the project when you configure the module using the Administrator application.
    #12881
    manyan2028
    hello Mikhail
    I donot know how to config the Option to achieve data transfer between rapidSCADAs。 In connection Option host is the remote PC IP,username admin password sacada 。 port and the TimeOUt is the default。 the instance and the Secret Key is null . uopload the Project to the PC .BUt I cannot rececive the Current Data in the Remote PC。can you help me to finish the test environment.
