Forum Home › Forums › Runtime Bugs › Webstation Bugs › Error calling the GetCurDataByView
- This topic has 4 replies, 2 voices, and was last updated 3 years, 4 months ago by
June 28, 2023 at 9:51 am #12887
quintelosky
ParticipantHi
I’m using rapidscada 6.1.
Ok, I logged correctly, works fine some minutes, and go to error. I don’t know what is the problem. I restart all, clear cookies, change user name,… I don’t know
2023-06-28 11:39:13 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Webstation 6.1.0.0 started
2023-06-28 11:39:13 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
2023-06-28 11:39:13 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgChart 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
2023-06-28 11:39:14 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgMain 6.0.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
2023-06-28 11:39:14 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
2023-06-28 11:39:14 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgSchBasicComp 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
2023-06-28 11:39:14 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
2023-06-28 11:39:14 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2023-06-28 11:39:14 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2023-06-28 11:39:14 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 11:39:17 [TCRLPLNETAP][TCRLPLNETAP$][ACT] The configuration database has been received successfully
2023-06-28 11:39:17 [TCRLPLNETAP][TCRLPLNETAP$][INF] The application is ready for operating
2023-06-28 11:39:58 [TCRLPLNETAP][TCRLPLNETAP$][ACT] User admin_1 is logged in, IP 10.64.86.100
2023-06-28 11:41:27 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
Incorrect format of data received from the server: unable to read data packet header
2023-06-28 11:41:28 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
Client is not logged in. Try again later.
2023-06-28 11:41:29 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:32 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:33 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:34 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:35 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:38 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:39 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:40 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:41 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
2023-06-28 11:41:44 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error calling the GetCurDataByView web API method:
Incorrect format of data received from the server: unable to read data packet headerJune 28, 2023 at 10:22 am #12888quintelosky
ParticipantHi
I disconnect lan, restart all, and continue the error
scadaweb.log:
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Webstation 6.1.0.0 started
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgChart 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgMain 6.0.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgSchBasicComp 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2023-06-28 12:18:17 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:18:19 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
2023-06-28 12:18:27 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:18:29 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
2023-06-28 12:18:37 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:18:39 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
2023-06-28 12:18:47 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:18:49 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
2023-06-28 12:18:57 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:18:59 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
2023-06-28 12:19:07 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:19:09 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
2023-06-28 12:19:17 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:19:19 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
2023-06-28 12:19:27 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
2023-06-28 12:19:29 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
Incorrect format of data received from the server: unable to read data packet headerJune 28, 2023 at 1:21 pm #12892
What is written in ScadaServer.log?July 7, 2023 at 7:48 am #12963quintelosky
ParticipantHi
Sorry for the delay
I changed 10000 port to 9999, and now works fine.
July 7, 2023 at 11:14 am #12965
Likely, the port 10000 is used by another application. -
