Forum Home › Forums › Understanding the Software › Elastic Report Flexibility
- This topic has 29 replies, 6 voices, and was last updated 2 years, 11 months ago by
June 23, 2018 at 1:28 pm #3896
jacklondon
ParticipantHi Mikhail,
i need different reports based on hours, shift (working) hours, daily, weekly, monthly… and any kind of time period.
Is “Elastic Report” able to define the report time period, i.e. for an 8-hours shift period?
regards
June 24, 2018 at 11:34 am #3898bencyau
ParticipantSame questions here on Elastic Report. Would like to be able to draw data from minutes and hourly data archive to report on hourly computations, and also for work shifts such as OEE reports (uses at least 3 channels of data).
The ElasticReportExample uses hourly data from 12pm, not sure how to extend that into one or multiple shifts. Also the use of formula in Excel format does not show how to reference values from related channels at the same timeslot.
Thanks.
June 24, 2018 at 2:04 pm #3900
MikhailModeratorCould you provide an example of a required report?
June 24, 2018 at 2:11 pm #3902jacklondon
ParticipantHi Mikhail, for example:
One needs to report different energy consumptions for every shift between 00:00-08:00, 08:00-16:00 and 16:00-24:00, additionally hourly, daily, weekly, monthly…
How to achieve that?
Regards
June 25, 2018 at 4:31 pm #3908
MikhailModeratorCurrently, possible values of the detailing parameter: Hour, Day, Month, BeginEnd.
It means that you can get consumption between every hour, every day, every month or between the beginning and the end of the selected period.To support custom time period and weekly period, the Elastic Report plugin should be updated.
Elastic Report uses hourly data. If you need minute data, please provide examples.
June 26, 2018 at 1:09 pm #3921jacklondon
… or between the beginning and the end of the selected period.
Could be an alternative solution, if we could enter not only the date, but also concrete beginning and ending time (hours) when we let create the report at the elastic report page… For example: Same day, but only the beginning and ending times differ!?
This reply was modified 7 years, 11 months ago by
jacklondon.
June 26, 2018 at 2:14 pm #3931
It requires an update of the plugin. We can discuss such development.
The solution that can be implemented using the current plugin version: use Excel formulas to calculate consumption for needed ranges of time. I mean you get a report with hour detailing and Excel refers to the specified cells and calculates required values.
July 5, 2018 at 6:38 pm #3968jacklondon
i think it would be enough for the beginning, to have also a range definition for hours (begin and end) additionally to date range at the page where we call an elasticreport, if possible!?
That way we could give the same date as begin/end and then define the hour range for example for shift begin and end.
Regards
July 6, 2018 at 2:51 pm #3970
Could you send me an email to this address? I will estimate a cost of the update and answer by email.
February 6, 2019 at 1:47 am #4970pitch26
ParticipantHow to set the elastic report to show the maximum value attained for the day of a channel?
February 6, 2019 at 1:07 pm #4973
MikhailModeratorYou need an input channel that stores max. value of each day. Than use this channel in your report configuration file.
November 13, 2020 at 1:02 pm #7533dinop
ParticipantHello,
I am new with Rapid scada and scada in common.
I am trying to figure out how does an Elastic report work.
Inside the program I opened a new Interface with .xml
Can someone give me an example of how to make a report for a daily/ shift consumption of energy for example. What to write inside the interface I opened, it begins with
<?xml version=”1.0″ encoding=”UTF-8″ ?>. #
What should I declare as input? Please some help with a pdf or some document that will make me understand how this works.
Thanks.November 13, 2020 at 2:18 pm #7539
MikhailModeratorDecember 7, 2020 at 9:35 am #7676dinop
ParticipantHello,
I need report based on hours, shift (working) hours, daily, weekly, monthly… and any kind of time period.
Is it possible to define report time period for 8-hour shift with ElasticReport?Thanks
December 8, 2020 at 5:31 am #7682
Please provide the report example.
Elastic Report allows to set a reading hour. -
