Multiple trigger conditions Automatic Control
Forum Home › Forums › Understanding the Software › Formulas › Multiple trigger conditions Automatic Control
  • #12850
    p.tranavicius
    Is it possible to set multiple trigger conditions in Automatic Control module,
    For example:
    Input channel value = 1 AND Input channel 2 > 20
    Much appreciated.
    Regards,
    Paulius
    #12855
    Hello Paulius,
    You should create additional channel of the Calculated type to calculate a condition. Then use that channel in the trigger.
    #12856
    p.tranavicius
    Something like the lines of code below in the formula?
    public double Mcon()
      if (Val(1) > 1 && Val(2) = 20) // my 2 limits
       return 1; // my trigger status 1
      else
        return 2; // my trigger status 2
    • This reply was modified 3 years, 5 months ago by p.tranavicius.
    #12858
    In general, yes.
    According to C/C++/C# syntax, the equality operator is ==
    Also you can check channel status, for example, Stat(1) > 0
