Add channel name in Input/Ouput channel parameters in Scada Scheme
Forum Home Forums Development and Integration Add channel name in Input/Ouput channel parameters in Scada Scheme
  • #12876
    anaisthrl
    We plan to implement a new form of notation for the parameters “Input channel” and “Output channel” in the properties of an object in Scada Scheme Editor (V5).
    The goal of this implementation is to intuitively know which channel is used.
    So, we add a “…” button:
    https://zupimages.net/viewer.php?id=23/26/8k18.png
    and an editor to allow users to choose their channel:
    https://zupimages.net/viewer.php?id=23/26/nif2.png
    Finnaly, the name of the channel appears with its NumChannel :
    https://zupimages.net/viewer.php?id=23/26/ag3r.png
    We want to precise that the initial Input channel and output channel ID was always update in the backend of this feature.
    Any advice or suggestion about this feature?
    #12879
    Sounds useful.
    Unable to open the links. Could you upload images to https://imgbb.com/ or Google Drive?
    #12886
    anaisthrl
    Yes sure.
    You will find the images here:
    https://ibb.co/wQv3yS9
    https://ibb.co/V293r1t
    https://ibb.co/7zhHVnc
    #12893
    Cool!
    Is it still possible to enter channel number manually?
    #12894
    I suggest using channel caption as [Number] Name
    #12895
    anaisthrl
    For the moment, we can’t enter channel number manually. The user choose an channel in the data grid view and the number of channel is wrote between ().
    But, if you prefere, we can adapt the code to show the channel number before the name . Like (number) name.
    • This reply was modified 3 years, 2 months ago by anaisthrl.
    #12900
    Such notation is used in many places in Rapid SCADA, for example, in Main Plugin and Chart Pro Plugin. So it should be comfortable for users.
