Modbus Float values
Forum Home Forums Communicating with Devices Modbus Modbus Float values
  • #12874
    scr910
    I am using holding registers (4x) as inputs to monitor temperature, which is a float in my PLC configuration. The values I get are extremely erratic and many orders of magnitude greater than my range (0-500). I believe this is an issue with how the bytes are mapped. The PLC software says: “floating point: two 16 bit registers, with the most significant bits in the first (or lowest address) register.” I have tried to change the byte order for this signal to match, but it looks like it should be 0123.
    Other inputs I have (INTs) which are only 1 register are working correctly.
    Any suggestions on how I can correctly read the modbus registers for my float signals?
    #12875
    Try 2301 order.
    If it does not help, please post links to screenshots of the Modbus template.
    #12877
    scr910
    This order worked – thank you! I swore I tried this order but I guess it was 3201 that I tried, oops! I really appreciate your quick response and look forward to using RapidScada.
    #12878
