Viewing 15 posts - 1,381 through 1,395 (of 6,288 total)
  • in reply to: Communicator Send only modified data of device tags setting #13772
    By default Communicator sends data on change and sends all data every minute.
    But on the screenshot you disabled sending all data because period = 0.
    Option 1
    Upload the project again from Windows to Linux after update.
    Option 2
    Copy the application files manually to keep the configuration unchanged.
    in reply to: Unable to view in browser #13770
    Please provide screenshot of the Interface table and a web page.
    Rapid SCADA 6 is recommended over version 5.
    in reply to: OPC DA to UA Gateway #13762
    To do that, you need to specify different configuration files for different OPC servers to use different TCP ports.
    in reply to: Issues and Error Handling When Starting a SCADA Project #13761
    This topic is about building Rapid SCADA 6 from the source code. Please ask your question in a proper topic.
    in reply to: V6 ChartPro features #13760
    Find the phrases in SCADA\ScadaWeb\lang\*.xml. You can change them. Then restart a web application.
    in reply to: Ubuntu instalation issue #13759
    Seems like the services are not running.
    First off all, check .NET as written above.
    .NET version 6 is required.
    in reply to: Minute Real not found in Rapid v6 #13750
    Yes, EveryHour function exists. You could open the Scripts table, then open the Timers script and find these functions there.
    in reply to: Data Exporting #13749
    In the module options disable Archive Replication for testing. Then check the log file.
    in reply to: V6 ChartPro features #13748
    The old approach was inefficient because the app had to load a view to know what channels are included.
    Probably we should improve the Select Channels form to provide additional channel filters which use the configuration database structure to select channels without loading views.
    Currently, may be creating several objects and binding channels to them can help to find channels.
    in reply to: Download or upload configuration #13747
    Use this advice.
    in reply to: Minute Real not found in Rapid v6 #13740
    In v6, use the Calculated channel type and input formula like EveryMin(() => MyFunction())
    in reply to: Data Exporting #13739
    You could start with providing correct MySQL connection settings.
    Also check ModDbExport*.txt files.
    in reply to: Grafana Integration on RapidScada 6 #13737
    Press F12 in browser and find the error details.
    You should enable displaying data in frames in the Grafana config.
    • This reply was modified 2 years, 6 months ago by Mikhail.
    in reply to: V5 and V6 installation #13736
    Any unassigned. I suggest to add 10000 to the default Rapid SCADA ports.
