Minute Real not found in Rapid v6
Forum Home Forums Understanding the Software Formulas Minute Real not found in Rapid v6
  • #13726
    kcks66
    Hi Mikhail,
    Previously I am using v5.8.4 and use default channel type Minute Real to sum up my value every minute. However in v6 doesn’t has Minute Real anymore.
    My previous script worked in v5.8.4 is as below:
    double GetSumOneMinute(int srcCnl, int desCnl)
    DateTime NowDT = DateTime.Now;
    double newVal = Val(srcCnl);
    double curVal = Val();
    double sumVal = newVal + curVal;
    SetVal(CnlNum, sumVal);
    if (NowDT.Minute == 0)
    SetVal(desCnl, sumVal);
    return 0;
    if (NowDT.Minute == 30)
    return 0;
    else
    return sumVal;
    Right now above script couldn’t work in v6. I got the value kept summing up every second.
    Pls advice for what to add into the above script in order to make it work in v6?
    #13740
    In v6, use the Calculated channel type and input formula like EveryMin(() => MyFunction())
    #13744
    kcks66
    Hi Mikhail,
    I got the “Minute Real” in V6 now. Thank you.
    By the way, if I want “Hourly Real” can I use?
    EveryHour(() => MyFunction())
    #13750
    Yes, EveryHour function exists. You could open the Scripts table, then open the Timers script and find these functions there.
    #13752
    kcks66
    Hi Mikhail,
    I found the functions. Thank you.
