Communicator Send only modified data of device tags setting
Forum Home Forums Understanding the Software Communicator Send only modified data of device tags setting
Viewing 10 posts - 1 through 10 (of 10 total)
  • #13767
    kcks66
    Hi Mikhail,
    I am exporting data to PostgreSQL. So far so good until when my energy meter stop counting and the energy number remain same value. I couldn’t get the energy data in PostgreSQL anymore although it should be always same value over the time.
    Is my Communicator Send only modified data of device tags setting? I leave it tick all the time.
    https://ibb.co/3v1vhTy
    Pls advice and thank you.
    #13772
    By default Communicator sends data on change and sends all data every minute.
    But on the screenshot you disabled sending all data because period = 0.
    #13773
    In version 6 you can enable PostgreSQL archives.
    #13777
    kcks66
    Hi Mikhail,
    Noted, I will change the period from 0 to 60s and check.
    This feature I didn’t try yet, will try and see soon.
    #13781
    By default PostgreSQL parameters are
    localhost
    User: postgres
    Password: postgres
    Database rapid_scada should be created manually.
    #13789
    kcks66
    Hi Mikhail,
    I need your help to guide me how to configure in both Rapid SCADA and pgAdmin.
    My Rapid SCADA configuration as below, is it correct?
    https://ibb.co/Fb956Xh
    I have no idea what to do next in pgAdmin. I can see user postgres here.
    https://ibb.co/d6s5tGL
    #13792
    In pgAdmin right-click the Databases node and create a new database, named rapid_scada
    #13797
    kcks66
    Hi Mikhail,
    Done created the new database.
    https://ibb.co/JH4BBGW
    Pls advice for next step?
    #13805
    Then you can enable PostgreSQL archives. For more details please create a new topic. This topic is about Communicator.
    #13808
    kcks66
    Hi Mikhail,
    Noted with thanks.
