V5 and V6 installation
Forum Home › Forums › Installation Issues › V5 and V6 installation
  • #13711
    XptoPT
    Good morning,
    Can I have the V5 and V6 version installed on the same Windows to work simultaneously?
    Thanks.
    Best regards.
    #13712
    If you need v5 and v6 running in parallel, you should use different TCP ports for the Agent and Server apps.
    It is easier to stop the services of v5 before running v6 and vice versa and use the default TCP ports.
    https://ibb.co/9hMpGGQ
    #13717
    XptoPT
    I had to do some tests.
    By managing the activation of services for each version, I can have each version working individually.
    But I’m not able to have the 2 versions working simultaneously, can you please explain in more detail where I should configure the TCP ports?
    Where should I have different TCP ports? In my project “General settings” or in the project upload settings?
    Thank you for your help.
    #13721
    Ports for v5 are kept by default.
    For v6:
    – Set Agent port in SCADA\ScadaAgent\Config\ScadaAgentConfig.xml Then restart the service.
    – Set ScadaServer port using the Administrator app.
    – Update Communicator and Webstation connection options.
    – Update the deployment profile in the project.
    #13732
    XptoPT
    Can I choose any port number, or do you have any suggestions?
    Thanks.
    #13736
    Any unassigned. I suggest to add 10000 to the default Rapid SCADA ports.
    #13745
    XptoPT
    Thanks, I’ll test it.
