Download or upload configuration
Forum Home › Forums › Understanding the Software › Download or upload configuration
Viewing 15 posts - 1 through 15 (of 21 total)
  • #5880
    Marko
    Hello Mikhail,
    I have problems with download configuration or upload i just can’t login correctly.
    From file:
    Error downloading configuration:
    Unable to login – Invalid username or password
    I am not sure which username and password procedure ask for. I want to download configuration from localhost. I did already open 10002 port i even try without firewall but that didn’t help.
    So first question is which username and password he want and where do i find it?
    Second question is, i want to migrate scada to 5.7.0 version and if i understand correctly you need to use download and upload configuration so you save that under some project in administration tool?
    • This topic was modified 7 years, 3 months ago by Mikhail.
    #5882
    If this problem occurs during migration, add a user ScadaAdmin with password 12345 to the Users table of the old configuration database.
    Look the error details in C:\SCADA\ScadaAgent\Log\ScadaAgent.log
    This document may help.
    #5883
    Marko
    I added user ScadaAdmin with password 12345 and application role. Pass that to server. I didn’t do migration yet. I wanted to download configuration from old version (5.6) and error occur with login.
    Also i wonder about system instance = default. Maybe i need to change that?
    I wanted to fix this before i try migration from 5.6 to 5.7. Thank you for that file about migration.
    ScadaAgent.log:
    2019-08-27 18:47:36 <computer_name><SYSTEM><ACT> Session with ID 3350479412239322651 created
    2019-08-27 18:47:36 <computer_name><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or password
    2019-08-27 19:01:40 <computer_name><SYSTEM><ACT> Session with ID -7675101413440856990 created
    2019-08-27 19:01:40 <computer_name><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or password
    #5886
    The “Default” instance is specified in the Agent configuration. I think, it’s OK.
    Did you pass the configuration to the server using the old Administrator?
    Agent looks for the user ScadaAdmin in C:\SCADA\BaseDAT\user.dat
    #5888
    Marko
    I view user.dat and i see there ScadaAdmin with password 12345 and roleID=4, after that i check roleID settings and 4 is application role.
    #5889
    Strange that you can’t connect.
    Other way to try:
    Click edit profile before reading the configuration, and change the user to ScadaWeb, also set correct password of ScadaWeb user.
    #5891
    Marko
    I tried with accounts: ScadaWeb,ScadaComm,ScadaServerCtrl and ScadaAdmin and still wasn’t able to download configuration. I also watched to input appropriate password for each account.
    #5892
    1. I can fix it remotely for a fee.
    2. There is also another way to port the existing project to the new version.
    2.1. Install Rapid SCADA 5.7.1 and make sure everything works well.
    2.2. Import the configuration database tables from the old configuration. I will provide more info how to import if needed.
    #5894
    Marko
    I will contact my boss but i think we will be more interested into method 1.
    #5959
    Marko
    Hello Mikhail,
    i want to apologize for late response but i talked with my boss and he will contact you about details for method 1.
    #5961
    Hello Marko,
    Good. Please write by email to discuss the details.
    #6622
    tom040264
    Hi guys,
    It must be a matter of my intelligence, but I can not migrate the configuration from the old to the new system. ?
    The current situation:
    PC with SCADA 5.6
    Laptop with SCADA 5.8 (new installation, without any problems)
    I understood that I have to download the current configuration (PC) and to upload it at the new SCADA (Laptop). Is it correct?
    Unfortunately I can not find any “idiot proved” step-by-step description. Can I access the old system directly from the new one (LAN – remote), or should I do it in two steps, PC and then laptop.
    Any try to download the configuration on the PC delivers an error message:
    “No listening endpoint present at http://localhost:10000/ScadaAgent/ScadaAgentSvc/&#8221;
    Regards
    Tom
    #6626
    Try this document. Also check Agent log file to be sure that it’s running. If you have more questions about version upgrade, please create a new topic because this one is inappropriate.
    #6627
    Agent uses port 10002. So 10000 is not correct. Change upload profile setting to the default.
    #13741
    chika
    Hello Mr. Mikhail,
    Previously, the Rapid Scada that I had was running normally, but currently the Rapid Scada can’t upload. How to fix it? (Error uploading configuration : Unable to login :- Invalid username or password)
    In user-> Role application :
    ID 4
    Name ScadaAdmin
    Password 12345
    ScalaAgent.Log is :
    Agent
    Started : 28/11/2023 16:26:54
    Execution time : 1.00:15:34
    State : normal
    Version : 5.0.2.0
    Active Sessions
    [-8879585298162833096] ::1; 16:42:09
    [-7801325152737781735] ::1; 16:42:19
    [-8318473730623925550] ::1; 16:42:14
    2023-11-29 16:42:09 <DESKTOP-RKOT85G><SYSTEM><ACT> Session with ID -8879585298162833096 created
    2023-11-29 16:42:09 <DESKTOP-RKOT85G><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or password
    2023-11-29 16:42:14 <DESKTOP-RKOT85G><SYSTEM><ACT> Session with ID -8318473730623925550 created
    2023-11-29 16:42:14 <DESKTOP-RKOT85G><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or password
    2023-11-29 16:42:19 <DESKTOP-RKOT85G><SYSTEM><ACT> Session with ID -7801325152737781735 created
    2023-11-29 16:42:19 <DESKTOP-RKOT85G><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or password
    Thank you
