V6 ChartPro features
Forum Home › Forums › Understanding the Software › V6 ChartPro features
  • #13743
    kcks66
    Hi Mikhail,
    I tried ChartPro in V6 and notice that the V6 Select Channels filtering is filter Object only. When I open the Object I see all channels were listed down, like below:
    https://ibb.co/hHXPXj5
    Is there any setting to be done in order that I can select desired channels from filtering Table like in V5?
    The Select Channel type in V5 is more easy for me to choose from the table to select the desired channel.
    Pls advice and thank you.
    #13748
    The old approach was inefficient because the app had to load a view to know what channels are included.
    Probably we should improve the Select Channels form to provide additional channel filters which use the configuration database structure to select channels without loading views.
    Currently, may be creating several objects and binding channels to them can help to find channels.
    #13751
    kcks66
    Hi Mikhail,
    Noted, will use different objects for different groups of channels.
    #13753
    kcks66
    Hi Mikhail,
    Can I change the word “Current” from table view?
    https://ibb.co/stHcn7Q
    #13760
    Find the phrases in SCADA\ScadaWeb\lang\*.xml. You can change them. Then restart a web application.
    #13764
    kcks66
    Hi Mikhail,
    Got it, thx.
