Ubuntu instalation issue
Forum Home › Forums › Installation Issues › Ubuntu instalation issue
  • #13755
    hugobraga
    Hello, after perform the procedure available in this link:https://rapidscada.net/docs/en/latest/installation/install-linux I get a “502 Bad Gateway” instead of login page. Checking the state of scada services I get the following erros:
    ● scadaserver6.service – Rapid SCADA Server
    Loaded: loaded (/etc/systemd/system/scadaserver6.service; enabled; vendor preset: enabled)
    Active: activating (auto-restart) (Result: exit-code) since Thu 2023-11-30 16:14:42 -01; 7s ago
    Process: 3889 ExecStart=/usr/bin/dotnet /opt/scada/ScadaServer/ScadaServerWkr.dll (code=exited, status=150)
    Main PID: 3889 (code=exited, status=150)
    CPU: 2ms
    nov 30 16:14:42 bragofsky-virtual-machine systemd[1]: scadaserver6.service: Main process exited, code=exited, status=150/n/a
    nov 30 16:14:42 bragofsky-virtual-machine systemd[1]: scadaserver6.service: Failed with result ‘exit-code’.
    nov 30 16:14:42 bragofsky-virtual-machine systemd[1]: Failed to start Rapid SCADA Server.
    The output is the same for all services.
    Help needed
    Regards
    Hugo
    • This topic was modified 2 years, 12 months ago by hugobraga.
    #13757
    check command
    dotnet --info
    What does it say in this part?
    .NET runtimes installed:
      Microsoft.AspNetCore.App 6.0.20 [/usr/share/dotnet/shared/Microsoft.AspNetCore.App]
      Microsoft.NETCore.App 6.0.20 [/usr/share/dotnet/shared/Microsoft.NETCore.App]
    #13759
    Seems like the services are not running.
    First off all, check .NET as written above.
    .NET version 6 is required.
    #13821
    hugobraga
    Hello Mikhail and manjey73,
    First of all thanks for your ressponse.
    Regarding the dotnet version here is my output:
    global.json file:
    Not found
    Host:
    Version: 6.0.25
    Architecture: x64
    Commit: 492abbeef0
    .NET SDKs installed:
    No SDKs were found.
    Microsoft.AspNetCore.App 6.0.25 [/usr/lib/dotnet/shared/Microsoft.AspNetCore.App]
    Microsoft.NETCore.App 6.0.25 [/usr/lib/dotnet/shared/Microsoft.NETCore.App]
    #13822
    hugobraga
    Hello, regarding this issue, as you can see I have dotnet v6 installed, previouslly I’m using v8. The fact is, right now all services are running.
    I have another question regarding this installation. Mikhail, is it possible to use the plugin’s purchased in the past in this linux setup? I’m specially refering to Notification and map plugin’s.
    Best Regards
    Hugo
    • This reply was modified 2 years, 11 months ago by hugobraga.
    #13825
    We update keys from v5 to v6 on the same machine for free.
    Common license terms are also work, please check this link.
