Viewing 15 posts - 3,586 through 3,600 (of 6,392 total)
  • in reply to: Acces the Modbus data from outside the LAN #7606
    Yes, it’s possible. For example, you can deploy a virtual machine on Google Cloud or Azure and run Rapid SCADA on this machine. Also it’s possible to provide access to your workstation from the internet. Depends on your needs.
    in reply to: Users, roles, rights #7603
    When you try to open AdvancedDashboard, there should be a record in ScadaServerSvc.log. Try to open the dashboard, then look in the server log.
    in reply to: Obtain data from different devices cyclically #7601
    I think Automatic Control module is necessary for this purpose. For testing, you can send commands manually from the web app.
    in reply to: Users, roles, rights #7600
    You should check that the file in C:\SCADA\Interface\Monitoring\AdvancedDashboard.xml exists. And also check C:\SCADA\ScadaServer\Log\ScadaServerSvc.log for some useful info.
    in reply to: Username and password #7597
    Try changing the passwords back to 12345. Then do this.
    We can fix this issue remotely for a fee in case of emergency. Contact us by email if needed.
    in reply to: Users, roles, rights #7593
    According to the icon of the AdvancedDashboard item, we can see that Dashboard Plugin is active.
    Check C:\SCADA\ScadaWeb\log\ScadaWeb.log for the error details.
    in reply to: Users, roles, rights #7590
    – explorer tree that contains views
    This image is also important. I mean the screenshot of the main page of the web application.
    in reply to: Users, roles, rights #7587
    Please also make screenshots of the web application:
    – installed plugins page
    in reply to: Server problem #7586
    Good 🙂
    in reply to: Users, roles, rights #7583
    Please provide screenshots of your settings and web interface.
    in reply to: Scheme Symbols/IMG #7579
    You need to download and install Extra Scheme Components.
    If it is installed correctly, in Scheme Editor you will see a Gauge component.
    in reply to: Scheme Symbols/IMG #7577
    On the screenshot there is a DynamicPicture component, but you need a Gauge component.
    in reply to: Users, roles, rights #7576
    Administrator already has full rights. You should clear the Rights table.
    in reply to: Is KPView’s AppDirs.ConfigDir different from that of KPLogic #7575
    Also KpLogic can provide a service like WCF or gRPC that is available from the KPView (from the project).
    in reply to: Is KPView’s AppDirs.ConfigDir different from that of KPLogic #7574
    The project should not be changed by runtime. If you need something like that, you should write changes to
    C:\SCADA\ScadaComm\Storage
    C:\SCADA\ScadaServer\Storage
    or to a 3rd party database and then use your data.
