Forum Home › Forums › Communicating with Devices › OPC › OPC communication logs
- This topic has 3 replies, 2 voices, and was last updated 6 years, 5 months ago by
May 20, 2020 at 1:54 pm #6853
ahamu
ParticipantHello Mikhail
I am using RapidSCADA with the Matricon OPC simulator server. It works well as instructed in the Youtube video tutorial. I want to log/capture all the communication between RapidSCADA client and Matricon OPC server. Could you please suggest how can I do so? I installed Matricon OPC sniffer, but it cannot find the installed Matricon OPC server on my computer.
I would appreciate responses to the following questions:
– Is it mandatory to restart server and communicator while uploading a project to RapidSCADA?
– Is it possible to run two different projects simultaneously on the same machine and view outputs on the webstation?Thank you very much.
Regards
AhamuMay 20, 2020 at 2:07 pm #6855
Does the OPC sniffer work with classic OPC (Midcrosoft OLE) or UPC UA?
Agent automatically decides whether to restart or not. It depends what settings was changed.
Do you mean to install 2 different Rapid SCADA on one machine?
May 20, 2020 at 6:24 pm #6857ahamu
ParticipantThank you for your response.
My responses to your comments are as follows:Does the OPC sniffer work with classic OPC (Midcrosoft OLE) or UPC UA?
Matrikon OPC sniffer is for classic OPC supporting OPC DA 2.0 and 1.0a specifications.Let me rephrase my questions again to help you answer precisely:
Is it possible to run the HelloWorld project and DemoPrject simultaneously in one machine?Agent automatically decides whether to restart or not. It depends what settings was changed.
When uploading a project to the server, there are two options to restart the server and communicator. When uploading the OPC Project I intentionally unchecked these two options. The reading and writing operations to the OPC are not working properly at the workstation. However, they worked as intended when both options are checked during configuration upload.
May 21, 2020 at 2:24 pm #6860
MikhailModeratorIs it possible to run the HelloWorld project and DemoPrject simultaneously in one machine?
It is possible to install to different Rapid SCADA on a one machine, and run 2 projects. But it’s not so easy. If you need more info about it, please start a separate topic. It’s better to deploy 2 virtual machines.
You should analyze the log files of Communicator.
