Dynamic text- forbid/ allow the writing/ input
Forum Home Forums Uncategorized Issues Dynamic text- forbid/ allow the writing/ input
  • #17558
    isalkic1
    I have dynamic text, dependent on the status of three channels- manual_mode, automatic_mode, and maintenance_mode. They are exclusive, meaning, only one is equal to 1 at the time.
    I want to allow text input in the dynamic text when the channel manual mode is equal to 1, and forbid the entry/ input when the modes/ channels either automatic_mode or maintenance mode are equal to 1.
    Is it possible to implement it?
    #17559
    You can send a Double.NaN in cases where the command should not pass, or cause an exception in the command with the message that commands are failed only in manual mode.
    #17564
    In new mimics, it’s possible to enable and disable components depending on channel value.
    If you use old schemes, you can reject commands as written above.
