Format and Unit and Formulas not working for InputChannels
Forum Home › Forums › Understanding the Software › Format and Unit and Formulas not working for InputChannels
  • #6868
    SergiScada
    Hi there,
    I’m having a weird issue. I have configured some Communication lines and Devices, for example one for ModBus and another one for MQTT.
    My problem here is that if I change for example the format, unit or formula in the input channel table for any of the channels of any device, the changes are not being applied when i upload the new conf and restart the server.
    I have tried to create a new line with a new device and configure the input channels this way at the first point but it isn’t work either.
    Any suggestion of what can couse this kind of problem.
    Here is some screenshoots of my current configuration and the results:
    https://imgur.com/a/3Dy9olU
    • This topic was modified 6 years, 4 months ago by Mikhail.
    #6870
    The changes should affect values that displayed on the web interface.
    Format in Communicator is defined by a driver.
    If you set -; True; False, it means that – is 0, True is 1 and False is 2.
    #6872
    SergiScada
    Thanks for the reply. Ok, I’ll try to display these values in the web interface.
    But i saw that this modifications are applied in the Administration view when i use the simulator exapmle.
    #6873
    SergiScada
    Okey, there we go!
    It’s working on the web interface.
    Thank you so much!
