Transfer historical data to DB
Forum Home Forums Understanding the Software Transfer historical data to DB
  • #17585
    oley
    I am currently using one instance with a standard dat archive.
    I want to use a PostgreSQL archive.
    Is it possible to transfer historical data to the database from the dat archive?
    #17586
    There is no direct converter. If you decided to develop it, I could help.
    Using the existing tools, you can export data to CSV, and then import it back from CSV to Rapid SCADA. When importing, data is sent to the Server service which writes it to the active archives.
    #17587
    I suggest to use DAT and PostgreSQL archives in parallel. In that case, you have 2 copies of data, fast performance when read DAT format, flexibility when read using SQL.
    #17589
    oley
    is there a specification of the dat file format?
    How to export complete historian data to csv?
    Writing an importer to existing DB with ef.core will not be a problem.
    #17593
    Yes. Please search in Additional documentation
    Use the utilities.
