Forum Home › Forums › Understanding the Software › 2 webstation or 2 instances
- This topic has 10 replies, 2 voices, and was last updated 6 years, 3 months ago by
Mikhail.
AuthorPosts
May 17, 2020 at 9:04 am #6843
arvxn01
ParticipantGood morning,
I don’t know if i need two webstations or 2 instances on a same project. For my project, i need to setup 2 webpages. One with buttons, switchs and leds. And the other one will show a part of a production line with engines, and others devices. And I want the 2 webpages communicate using internet with IP.
I have any idea of how i can do that. Need help 🙂
This topic was modified 6 years, 3 months ago by
Mikhail.
May 18, 2020 at 2:06 pm #6847
MikhailModeratorHello,
It’s possible to deploy 2 instances of the Webstation application. However, why not create 2 pages in a one Webstation?May 18, 2020 at 2:11 pm #6850arvxn01
ParticipantHello,
When I want to create a second instance, i have some errors about deployment profile. It says “Instance not found – Failed to login”.
Can I have the same deployment profile than the first instance. If the first is on 127.0.0.1/scada. What will be the adress for the second instance ?
May 19, 2020 at 2:55 pm #6851
MikhailModeratorCould you explain what is the reason of the 2nd instance?
For the 2nd instance, you need the 2nd deployment profile.
Address of the instance depends on the server where you deployed the instance.May 19, 2020 at 3:04 pm #6852arvxn01
ParticipantFor my project, I have 2 computers not on the same wifi network. On the first one, I want webpage with buttons, switchs and leds to control the second webpage on the second computer. The second webpage will contains images of engines and others devices. The state of these simulated devices will be controled by the first computer. And for that, I need to use IP.
I don’t if I need to install RapidScada on the both computers ? And I can configure the second deployment profile ..
May 20, 2020 at 2:04 pm #6854
MikhailModeratorMy be you need 2 different Rapid SCADA and 2 different projects.
The 1st project for simulating. And the 2nd project for control the simulated system.May 20, 2020 at 2:33 pm #6856arvxn01
ParticipantYes, I have two computers. What I need to do this configuration ?
Do I need install Communicator, Server and Webstation on the both computers ?
And how I can setup the second deployment profile for a computer which is on another network ?Thanks for your future answer.
May 21, 2020 at 12:12 pm #6859arvxn01
ParticipantI have 2 computers with Rapid SCADA so 2 different projects.
The 1st project for simulating. And the 2nd project for control the simulated system. I don’t know if I need to use port forwarding on my router or use the firewall with advanced settings ? Because, I want the 2nd project controls the simulated system using Internet connection.Please for your future answer ?
May 21, 2020 at 2:28 pm #6861
MikhailModeratorI don’t know if I need to use port forwarding on my router or use the firewall with advanced settings ?
Yes, you need to allow access from the Internet to LAN on the router. And also open an appropriate TCP port on Windows firewall.
May 22, 2020 at 9:28 am #6863arvxn01
Please explain me how I can configure Communicator on the first and the second project. I have already set up the firewall and the port forwarding.
May 22, 2020 at 1:12 pm #6864
There is not enough information about the system you build.
AuthorPosts
- You must be logged in to reply to this topic.
