Viewing 15 posts - 4,726 through 4,740 (of 6,290 total)
  • in reply to: Export to Database Module #4039
    You should check the log file of the module to find the cause.
    MySQL is owned by Oracle Corporation ))
    in reply to: HourBeg Function #4038
    This approach is useful to store values in the archive in the beginning of a new hour and then reset them, for example.
    You can write HourBeg2() with your own logic.
    in reply to: Responsive Web Design #4026
    The bug is fixed and the fix will be included in the next version of Rapid SCADA in August or September.
    Thank you for your help.
    in reply to: HourBeg Function #4025
    Where in the source code these lines are located?
    in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4023
    If you have some experience with Win 10 iOT, please share your opinion.
    in reply to: Install exe. file Rapid Scada on Raspberry PI 3 #4022
    Answered here.
    in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4021
    I suppose, the special port of Rapid SCADA should be implemented for Win 10 iOT. This is not a normal operating system, it has restricted .NET Framework and usual applications don’t work on it.
    To be honest, I don’t think this is a good idea, and I don’t see the future of Win 10 iOT. May be I’m wrong.
    in reply to: Responsive Web Design #4020
    I will check and write here.
    in reply to: String Length limit in Scada Admin #4019
    If possible, make a file name shorter. You can edit the table structure in ScadaBase.sdf file and change the field length, but it is not recommended.
    The issue is known, in a new version of a database the field will be longer.
    in reply to: Numerical display is wrong #4018
    If you have a formula for an input channel, it affects. You didn’t provide a screenshot of the input channel, so I’m not sure.
    in reply to: Responsive Web Design #4008
    How to reproduce the issue on my side?
    in reply to: Numerical display is wrong #4007
    The single digit display cannot be 0.2.4.6~…..
    Ten digits display normal
    I don’t understand the question. Could you explain?
    in reply to: Export to Database Module #4004
    In the Current Data tab you need to enter INSERT request only. Other SQL scripts are needed for creating the database.
    in reply to: Remote commumicator #4001
    rsepulve,
    it would be clear if you provide screenshots of your settings.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #4000
    IP address of a GSM device is specific to a telecommunication company. Sometimes they provide real IP for extra fee. This approach is not flexible. That’s better when a modem connects to a server.
    IP addres I have to put in coomunication settings dor slave devie?
    IP not needed if a modem initiates a connection.
