HourBeg Function
Forum Home › Forums › Understanding the Software › Formulas › HourBeg Function
  • #4024
    jacklondon
    Hi Mikhail,
    could you please explain why the hour beginning condition is entered as
    nowDT.Minute == 1
    and not
    nowDT.Minute == 0?
    Regards
    #4025
    Where in the source code these lines are located?
    #4032
    jacklondon
    They are taken from “CalcEngine.cs”, Formulas Table HourBeg():
    bool HourBeg()
        DateTime nowDT = DateTime.Now;
        DateTime execDT;
        if (nowDT.Minute == 1 && (!HourBegDict.TryGetValue(CnlNum, out execDT) ||
            execDT < new DateTime(nowDT.Year, nowDT.Month, nowDT.Day, nowDT.Hour, 0, 0)))
            HourBegDict[CnlNum] = nowDT;
            return true;
        else
            return false;
    #4038
    This approach is useful to store values in the archive in the beginning of a new hour and then reset them, for example.
    You can write HourBeg2() with your own logic.
    #4055
    jacklondon
    Hi Mikhail,
    Yes, i understood that already. The question is why you implemented it the condition nowDT.Minute == 1 (and not == 0) as the hour begins with for example 12:00.
    Regards
    #4059
    If you change it to == 0, the function may be executed before hourly data are stored in the archive. In most cases this doesn’t fit.
    How do you plan to use this function?
