Modbus TCP over GPRS (S27x GPRS RTU)
Forum Home › Forums › Development and Integration › Modbus TCP over GPRS (S27x GPRS RTU)
Viewing 14 posts - 1 through 14 (of 14 total)
  • #3973
    rsepulve
    Hi, Mikhail.
    I´m newer in Rapid Scada, about 6 month using it. It is great app.
    I´ve connect some PLCs and RTU M120T with success.
    But now I’m trying to connect 3 different models of over GPRS MODBUS TCP IP RTU.
    S272 from King Pigeon.
    WCT5018 from
    F2864 from Four Faith.
    But I don´t know how to configure the Communicator Channel in Modbus.
    I´cant poll the devices because the layout of GSM networks, only the RTU can send data to central server.
    I would like to ask if you have experience in that matter and if you have some tips to do that.
    If you want I can sent to you the manual, protocol structure and other things.
    Best regards.
    Thanks.
    Rodrigo Sepúlveda from Chile.
    #3974
    Hi Rodrigo,
    Usually a modem is TCP client while Communicator is TCP server. You should set the TCP server type of communication channel in Communicator and allow the incoming connection on Firewall. Setup a modem to connect to the IP or DNS name and TCP port of your server. You will see that a connection is established in a communication line log. If connection is OK, Communicator polls the devices.
    If something goes wrong, provide logs of the communication line.
    #3998
    rsepulve
    Hi Mikhail,
    Thanks for the information, but my problem is IP addressing.
    For server no problem,Use a public IP and Nat the 502 TCP port to internal IP address. But, what IP addres I have to put in coomunication settings dor slave devie? Private or Public of remote GSM RTU?
    Thanks.
    #4000
    IP address of a GSM device is specific to a telecommunication company. Sometimes they provide real IP for extra fee. This approach is not flexible. That’s better when a modem connects to a server.
    IP not needed if a modem initiates a connection.
    #4056
    rsepulve
    Hi Mikhail,
    What should be the right configuration in communicator for Modbus TCP protocol?
    Thanks.
    #4058
    This question is too general. Many configurations are right. One of the possible examples is included in the default configuration.
    #4061
    rsepulve
    Hi Mikhaeil,
    Sorry, I reffer to the communicator side looking to GSM RTU.
    for example I have 2 RTUs.
    One with Modbus RTU and other with Modbus TCP.
    You talk about if the RTU start communication, don´t matter the remote IP addres, how I have to configure the channel setting type tcp cliente, tcp master, in properties, master, Slave, connection individual, shared, etc.
    That is confused to me.
    I´ve put in GSM RTU, the public address and TCP port 502.
    In the router I´ve forwarded the 502 port to internal IP addres of Communicator and SCADA server.
    I´ve looked in the ethernet port that the data is coming to Server, but I confused to manage the response or polling from server to Remote GSM RTU, If I choose TCP, I need to put a remote IP address, wich, public GSM RTU or private GSM RTU, or what is the other config that doesn´t need the remote IP address?
    Thanks for your response and time.
    #4062
    Could you configure Communicator based on your intuition, then try the configuration? In case of issues, share screenshots with the settings and communication logs.
    Try TCP slave first.
    #4063
    rsepulve
    Thanks Mikhail,
    I’ll try.
    #4815
    waplet
    Sorry for bringing up old post, but i currently have similar issue. Have you got it working?
    Do you have a device template for S272?
    #4816
    I suppose, you should provide links to screenshots of your settings and copy communication log here.
    #5872
    born2dive
    Same problem with king pigeon device S266 with cellular. Any solution?
    Regards
    #5876
    Please provide the detailed description of the recent issue.
    #7134
    LissieMayo
    Hello…i believe you can utilize the Moxa module with GPRS modem, AirLink Fastrack Xtend programmable GPRS modem, or get any GPRS modem and inserted framework with Linux.
