How to install scada on Raspberry Pi using Windows 10 IOT
Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › How to install scada on Raspberry Pi using Windows 10 IOT
  • #4015
    Shailesh Singh
    Dear Sir / MAdam
    I want to know how to install scada in raspberry pi 3 using Windows 10 IOT ? please help me…..? if i have a exe of scada system then how to implement in raspberry pi-3 ..?
    #4021
    I suppose, the special port of Rapid SCADA should be implemented for Win 10 iOT. This is not a normal operating system, it has restricted .NET Framework and usual applications don’t work on it.
    To be honest, I don’t think this is a good idea, and I don’t see the future of Win 10 iOT. May be I’m wrong.
    #4023
    If you have some experience with Win 10 iOT, please share your opinion.
    #4036
    Shailesh Singh
    Thank you so much Mikhail for the tine you give me.
    please help me step by step what i will do for install scada system in raspberry pi 3 b+. and which OS is best for raspberry pi Raspbian Or windows iot.
    #4041
    I recommend Raspbian of the actual version. The step by step installation manual is included in the Linux distributive of Rapid SCADA.
