String Length limit in Scada Admin
Forum Home › Forums › Understanding the Software › String Length limit in Scada Admin
  • #4014
    catcute
    Hi
    I have problem when config the Interface/Path in Scada Admin. It is limit to 50 Symbols. Is there any way to overcome this issue?
    Error with length of Interface/Path
    Thank you!
    #4019
    If possible, make a file name shorter. You can edit the table structure in ScadaBase.sdf file and change the field length, but it is not recommended.
    The issue is known, in a new version of a database the field will be longer.
