MikhailModeratorAugust 31, 2025 update
Fixed a bug when adding a component
MikhailModeratorThe string length is limited by the Administrator application. Actual length can be bigger.
You could manually edit Format.xml in a text editor, e.g. Notepad++.
Then reload the project or configuration database.August 28, 2025 at 10:11 am in reply to: Cannot Access http://RapidScadaIP:10008 from Other Computers in LAN #16935
If you use *.dat archives, they record data with a fixed period. So the number of records is constant.
If PostgreSQL archives are used, you can count the number of records by SQL request.
MikhailModeratorRapid SCADA 6.4.2 has been released.
Server:
– Archives support monthly writing period
– Added an option to continuously recalculate to the difference calculator moduleCommunicator:
– OPC UA driver has improved reconnection to the OPC server. Implemented channel-based subscription creationWebstation:
– Beta version of new mimic diagrams included
– Comamnd API is available by default
– Changes in the plugin APIAdministrator:
– The length of the Code field increased
– Added more cultures in the culture list
> how many values were read for each channel
Please clarify what does it mean “how many values were read”?
MikhailModeratorIf another software opens the port, it cannot be opened by Rapid SCADA.
The software should try to open the port when it is available. What is in the log?August 21, 2025 at 12:13 pm in reply to: How to display selected command text in a Dynamic Text element #16902
MikhailModeratorIn Rapid SCADA it’s a bit different:
When you click a button, a popup dialog is shown, where you can choose an option.
To do that, you need to configure a channel of the output type. Then specify the channel number in the button properties.
MikhailModeratorPlease don’t mess up many topics in one. Create new topic for other questions.
Archive kind should be set to historical.
MikhailModeratorManually add a row in the Archives table.
If you provide screenshots, I can check.
That’s interesting!
MikhailModeratorYou can write data on change. It is supported by PostgreSQL archives.
> Just for a selected channel, not all of them.
It’s needed to create a new archive in the configuration database and in the Server settings. The created archive should not be marked as default. Then you can set an archive mask of the channel to write that channel to the certain archive.
Ask for the details if needed. -
