Forum Home › Forums › Installation Issues › New release Rapid SCADA 6.4.x
- This topic has 7 replies, 1 voice, and was last updated 3 months, 2 weeks ago by
January 23, 2025 at 1:32 pm #16100
MikhailModeratorRapid SCADA 6.4.0 has been released.
Fixed bugs found by the community.
If any additional paid modules are used, update them.For developers:
– The API of the modules has changed. Recompile your modules and publish the updates.
– The module registration form now supports custom hyperlinks to receive keys.April 1, 2025 at 2:58 pm #16294
MikhailModeratorRapid SCADA 6.4.1 has been released.
– Improved API of plugins and extensions (backward compatibility is supported)
– Fixed errors in MQTT and DB Import drivers
– The Server service writes initial command values to events before calculating by formula
– PostgreSQL historical archive supports in-memory cachingThe projects are fully compatible with the previous release.
August 26, 2025 at 2:32 pm #16926
MikhailModeratorRapid SCADA 6.4.2 has been released.
Server:
– Archives support monthly writing period
– Added an option to continuously recalculate to the difference calculator moduleCommunicator:
– OPC UA driver has improved reconnection to the OPC server. Implemented channel-based subscription creationWebstation:
– Beta version of new mimic diagrams included
– Comamnd API is available by default
– Changes in the plugin APIAdministrator:
– The length of the Code field increased
– Added more cultures in the culture listSeptember 24, 2025 at 11:20 am #17102
MikhailModeratorRapid SCADA 6.4.3 has been released.
– Upgrade new mimics
– Downgrade Npgsql.dll due to compatibility issues.It makes sense to update from 6.4.2 to 6.4.3 if the above changes are needed.
December 20, 2025 at 8:47 am #17438
MikhailModeratorRapid SCADA 6.4.4 has been released.
This is a maintenance release required for further development of the system.
– Minor bugs have been fixed.
– Reports now display the name of the user who generated the report.Useful link:
All commercial modules in a single archive.February 27, 2026 at 9:00 am #17687
MikhailModeratorRapid SCADA 6.4.5 has been released.
– New mimic diagrams and components have been updated.
– Historical data reading has been implemented in the OPC UA driver.
– Bug fixes.April 14, 2026 at 12:55 pm #17845
MikhailModeratorRapid SCADA 6.4.6 has been released.
Upgrade new mimics:
– Supports custom CSS and JS
– Text component supports conditions for selecting text
– Scripts of child faceplate components are executed
– Custom scripts are executed in edit mode
– Exported faceplate properties can be linked to mimic document properties
– Exported faceplate properties contain default bindingsJune 24, 2026 at 9:40 am #18079
MikhailModeratorRapid SCADA 6.4.7 has been released.
– Communicator API has been updated. Backward compatibility is maintained. Existing drivers do not need to be rebuilt.
– New RS Client Driver for interacting with another Rapid SCADA instance. Useful for publishing calculated channels via an OPC UA server.
– New Redundancy Selector Driver included in the Enterprise edition. This driver selects tag values from one of two devices.
– Fixed bugs in new mimic diagrams. -
